Traffic Loader error no. 10932
I have problem with traffic loader. I’ve made a simple model of quad, and I’m trying apply TS and UDL load with Traffic loader, but there is a error.
Someone have an idea what I did wrong?
traffic loader.sofistik (40.9 KB)
OK, I actually found a solution. Before running ELLA, you need to calculate at least one load case using ASE. After that, ELLA works without errors.
For example, I have 3 lanes (TS-300, TS-200, TS-100), and I create 4 combinations of these lanes using ELLA. My question is: will it be possible to obtain the support forces for set no. 1, set no. 2, and so on?
I’d like to achieve
1’st combination - overloading bearing no. 1 and additional forces of the bearing 2 and 3
2’nd combination - overloading bearing no. 3 and additional forces of the bearing 1 and 2
3’rd and 4’th combination - overloading bearing no. 2 and additional forces of the bearing 1 and 3
