Does anyone have references or examples in Sofistik to evaluate the effect of track structure interaction according to UIC 774-3R, particularly for continuous bridges with a single fixed pier?
I am working on a Sofistik model to analyze the restraint effects of an unballasted track on the deformation of the bridge deck. Any guidance or shared experience would be greatly appreciated.
Thank you in advance!
Hi there, I've recently done this analysis. Out of curiosity, are you doing train-track bridge interaction (TTBI), or rail-structure interaction (RSI)? If TTBI, you can define a MDOF train model in CADiNP like this example https://docs.sofistik.com/2023/en/tutorials/dynamics/rolling-stock/rolling-stock.html. There is a limitation that you need to run it along a track centreline. Do you have rail clips connected to the superstructure? Don't forget to use the nonlinear work law property of SPTS. If doing an RSI in ASE, activate nonlinear analysis option. Best, Benjamin Klassen (ARUP)
– benjamin.klassen
