I’d like to hear from anyone who’s worked with the topography function in Bridge Builder about how you use it. Do you leave the element as a generic model? Do you create a Revit Topografic element from the generic mass created from Sofistik? My project derives the topography from point cloud. Does anyone have any input on the workflow?
There are several option to create a terrain. In Autodesk Revit 2023 and older the SBIM provides the only solution to create a terrain volume out of a topography or by importing land.xml data
see this video, how it works.
Iy aou have a point cloud, I would use civil3d first to create a DGM from this point cloud. Then export the DGM in a land.xml file an import it into SBIM
