I have a question regarding the speed of calculation. In attachments I am sending the screenshots from the calculation of nonlinear analysis of building. The workstation has 64 cores (AMD Threadripper 3995WX) they are all running during iteration process, but as you can see, the initialisation of the calculation took 1434 seconds.
This process as you can see on the image 1 below took 1434 sec.:
Then iteration started - image 2
And final calculation time was 1643 sec (image 3):
I would like to know that if it is also possible to speed up this initialisation process? On the workstation is 512 GB of DDR4 3200 MHZ RAM with ECC and 2 NVME SSD disc in RAID 0 configuration, with 13 GB/s read and 7,5 GB/s write speed. So if it is possible to utilize RAM or SSD disc speed?
