I am having a problem with the Revit file in which I am drawing reinforcement.
If using Sofistik commands I get this message
The parameter is read only.
I can not modify anything with Sofistik tools.
Thank you for your help, Marko.
Hello @marko,
This seems to be a case for support(at)sofistik(dot)com Please describe a bit your problem and send us also your model to be able to investigate what is happening there.
The description should sound like this:
