Terrain as Toposolid instead of generic
Hi all,
I’m experiencing difficulties importing a Civil 3D surface into Revit because Revit doesn’t understand breaklines on a surface.
I need a toposolid to be able to design urban architecture on my project.
I was able to “Import” as a land XML and it’s perfect (The right picture), but whe i use the Import as Toposolid (The left of the picture)
Anyone knows how to convert from the generic type to toposolid ?
Hi!
There is no way to convert it. But instead of using the command “Import” I’d advise you to use “Import as Toposurface” and depending of the version you can choose to get a toposurface or a toposolid.
> SOFiSTiK Bridge + Infrastructure Modeler 2026
