Greetings,
I am currently modeling a single-span bridge with precast girders. The issue I am facing is that I am unable to extract forces at the top of the strip footing. I have tried creating support lines, but the results are not adequate. The problem is that when I apply a line with support conditions, I can only obtain support forces in kN and support moments in kN/m (these forces represent nodal values). However, the values I need are in kN/m for forces and kNm/m for moments, which correspond to the units for line supports (strip footing).
I need to extract these forces because I want to analyze the strip footing in another software. Essentially, the values I require correspond to distributed forces, not nodal ones.
Basically i want to see forces and moments which are present on white line. Also it would be great if i could extract those forces at bottom of strip footing.
Kind regards
