I’ve installed SSD 2023 and i have a strange problem: when i create a new cross section with “New standard section”, followed by “Steel profile”, the selected steel profile doesn’t shows up under the Cross Sections. Other sections (eg concrete sections or cable sections) are functioning without any problem.
Any idea?
This is indeed a strange behaviour. I tried to reproduce your descirbed problem, but with no success.
Just to be clear, you can’t create a standard steel section in the SSD as show in the picture bellow?
They sent my colleague a test project, but even there I can make a standard HEA-100 steel profile…
Just to check, you are working with an educational licence and the latest service packs?
The modified project works perfect. I can see the steel section you’ve mcreatde and, in this modified project, i can create new steel sections by myself.
Changing the design code (i’ve used EC and DIN allready) doesn’t solve the problem. Also, using a different input engine (Rhino, Sofiplus) doesn’t solve the problem either.
OK so I don’t think this problem can be solved without seeing all of the log files. Please send us your project files via the SOFiSTiK Application Manager.
