Is it possible to use Rhino 8 with older sofistik versions like 2022 or 2023? Sofimanager shows this information.
It is neither tested nor recommended to use other versions than the mentioned (see SAM) ones. Otherwise Rhino 8 would be listed.
Therefore answer from me: No
Wise answer, Thank you!
