Dear all!
How can I change steel type in automatic reinforcement by Sofistik Reinforcement Generation? I haven’t found it in constraints files.
Helen
Dear all!
Helen
Hello @Helen,
You are right, the material is not setted from the constraint files. SOFiSTiK Reinforcement Generation uses the material already setted in Revit for Structural Rebar category. Simply check the category in Object Styles as shown in this picture:
Hope that answered you question!
@andrei , thank you so much for answering!
But if I cange this parameter, sofistik reinforcement generation is still using the same steel types. Even if I change materials for all reinforcement diameters
Helen
Hi @Helen
You are right, we are using only the material from the Category (not subcategory or modified “by instance”).
We fixed this issue in the upcoming service pack. which will be release in 2-3 weeks.
Please wait for Service Pack 11 for RCD 2020 and 2021.
BTW, also in the version 2022 this is fixed, which will be released a bit earlier as the Service Pack for the older Revit Versions, at the beginning of the next week .
Andrei
Hello @andrei
I’m very much looking forward to that
Helen
