Sofistik Plugins doesnt run in Rhino/GH
I have installed the Rhinocerous plugin from the SAM. in the Plug-in center of Rhino it says the Sofistik plugin is installed but in Rhino interface /Grasshopper those plugin does not run even though it is successfully loaded :
Also the plugin are missing in Grasshopper Menu and Sub-Menu
Which version have you installed?
If it’s 2024-6 or 2025-0, then I have the same issue as yours.
BTW: Have you intsalled Sofistik plugins for Revit 2025?
I have some issues too.
Yes downgrading to 2024-5 helps.
It seems that this is not my personal issue.
The Sofistik Rhino interface 2025-0 and / or 2024-6 does have problem.
@netsonic_Sofistik I have the same issue over here.
Thanks for the reply.
This is the 3rd failure case
After installing the recent update everything seems to work now :slight_smile:
