Sofistik analysis file cdb (Revit user)
Good morning
i’m a revit 2021 user and i have a question about the files CDB.
are these files a database from sofistik or are they generated based on the model designed on revit?
if it is a database, where can i download it?
thanks a lot
regards
Hello Roberto
The .cdb is the SOFiSTiK database and contains most of the data of an SOFiSTiK project.
Normally the .cdb is saved in the same project folder as the .sofistik file.
If you are working with Revit, the .cdb can be found in the hidden .SOFiSTiK folder.
Further information about the .cdb can be found in the basic SOFiSTiK manual.
SSD / TEDDY > Help > User Manuals > Basic Manual > chapter ‘2.6 Database’
hello @JFH Thanks a lot for you answer
yes i found the file but when i try to open it, it gives me an error
any idea?
thanks a lot
Can you open the .sofistik project with the SSD?
If not, the files might be corrupted and you have to recalculated the project.
