The model (SofismshC SLN) is generated in Grasshopper, and it works in Sofistik.
The error occurs when I try to extrude them to QUAD in SofimshA
+PROG SofimshA urs:3
HEAD
SYST REST
GRP 11
QUAD PROP MNO 1 T 10[mm]
EXTR TYPE FROM TO PATH V1 V2 V3 DIV
SLN 'GRP' 1 DIR 0 0 0.5 1
It shows errors as below
SOFiSTiK 2022-3.0.738 SOFIMSHA - IMPORT/EXPORT FEM
Output on file 1. Run me.plb
Project data base 1. Run me.cdb - 3. access
Workspace 38.1 Megabyte
+++++ error no. 2300 in program SM_EXTR_SELECT_EDGE ; input line: 11
Unsupported option: GRP not recognized or incompatible within this context
+++++ error no. 2241 in program SM_EXTR_EXTRUDE ; input line: 11
No elements could be detected.
+++++ warning no. 2165 in program SM_EXTR_EXTRUDE ; input line: 11
Input is not supported for a dynamic group divisor GDIV<0
I tried GRP w/ and w/o quatation marks, the same errors
The teddy files are attached, please remove “.dat” , unzip it and run “1. Run me.dat”.
1.zip.dat (5.4 KB)
