I realized there is an issue with typing in the leg lenght when using X2 shape code.
When typing in the value lets say 2,00 m instead 3.7029 m, the program ignores my value and proceeds with 3.7029.
Hi @TomazSabec, you are right this is not that intuitive.
at this point you should hit down-arrow-key from keyboard and chose “delta” then show a line wherefrom you want to make this delta and then type the desired length. it will pop out an arrow suggesting the positive direction, of course you can give it also a negative value
It also does not work.
