when putting in concrete cover 0 cm, reinforcement bar aligns to its center
when putting in concrete cover some small value 0.0001 cm, reinforcement bar aligns as it should.
Is there way to put in 0 cm and rebar aligns to its perimeter as it should?
Thanks Tomaz
JFH
2
Hello Tomaz
Have you tried to reduze the minimmum plotted bar diameter?
Maybe your problem is just a visualisation problem.
that is not the case.
When laying a position as cut and using concrete cover 0 cm is not the same as
when editing laying and using formwork for range and using concrete cover 0 cm.
Is it minor issue.
Tomaz
