Hello:
I should like to know whether it is possible to put SIR cuts in groups, so as to effectively have an output display (for example, two direction cuts in a plane element that I could see one by one).
Thanks and regards.
Hello:
Thanks and regards.
Any SIR cut or Design Element gets a number. By selecting the numbers properly, there should be no problem to select them in any further processing.
But the group mechanism ist available only for elements and can be defined only during mesh generation
I remember I asked this question in the previous forum. It’s true that you can select the SIR cuts with their numbers in further processing; but assuming you are visualizing the structure in Wingraf, if you could hide certain SIR cuts, it would be very convenient.
The curious thing is that the SIR cuts created via Wingraf can be assigned to groups…
