How can I solve this issue? When I initiate the sail dimensioning task, the software gives the error message: 'No bracing sail is defined in the database
in order to use the shear wall design task you have to create design elements of type shear wall in Sofiplus.
I recommend having a look at our tutorial:
https://docs.sofistik.com/2024/en/tutorials/building/building-seismic-sofiplus/building-seismic-sofiplus.html
Nora
