As I need to find the stress in some points in my section, I defined points that I added in the section attributes as seen in the picture below:
Therefore, in the Teddy generated, a MNO 0 is affected to those points, and I am not being able to find the points in the Design results in Wingraf :
When I remove MNO 0, I get the result I want.
So I need to know how to remove the MNO 0 generated from Grasshopper not manually, but automatically from the Grasshopper canva
Thank you in advance
Christel S.
