I’ve been using secondary groups a lot in the past while programming in Teddy.
I’ve now started modelling a structure in SOFiPLUS and it would seem that using secondary groups in SOFiPLUS is not possible? Is this correct?
Dear Mrch,
correct, it’s not possible to use secondary groups in SOFiPLUS.
Cheers, Adrian
hm, that’s disappointing
Thanks for reply
Even if it is not possible in SofiPlus to use secondary groups, you can add them later on for further use.
From now on you can use secondary groups like you are used to. E.g. in Grafics, BEMESS
Regards
gmay
