SBIM Dynamo Axis creation
Hi everyone !
I am new to the Dynamo Nodes Library of SBIM and i am having some difficulties on how to create the axis definition (geometry, cruvres, etc); Can anyone help me ?
I attached some examples about Axis creation.
Regards.
sbim_04_landXml_Import.dyn (18.9 KB)
sbim_03.dyn (84.4 KB)
sbim_05_byCurve.dyn (35.7 KB)
sbim_06_byCurveReference.dyn (16.2 KB)
sbim_07_byModelCurve.dyn (16.0 KB)
sbim_08_byPoints.dyn (46.4 KB)
Thank you for your help and taking the time to answer ! Much appreciated
Hello again, i am sorry for bothering you with my many questions ! Your sample files were really helpful when it comes to axis creation. But right after finishing that task i still needed to understand the principle of the workflow. I couldn’t make further progress in placements, stations, …
Do i always need to work as if i’m using the basic Dynamo tasks (create point, create cruve, etc) to create elements, cross sections and then at the end assign them to a SBIM element ?
My regards and appreciation !
Also I can’t seem to find any documentation for the SBIM package for Dynamo. Is there one at least ?
Basically the Dynamo Nodes are an interface to the SBiM Core functionalitires, exactly as the standard GUI in the Revit Environment. Then all the input that usually is generated in the Dialogs should be build by the Entities or Conceptual-Objects, namely Axis, Superstructure, Parapet, etc. and on a second step the actual Revit-Element must be created in order to reflect the SBiM-Entities in the Project Database. However some Object are abstract definitions only, such as the Variables or Placements, and they does not have an Revit-Element counterpart.
I attached other samples that shows how to create some Components.
sbim_13_computeGeometry.dyn (9.5 KB)
sbim_14_superstructure.dyn.dat (81.3 KB)
sbim_15_substructure.dyn (42.6 KB)
sbim_16_repeater.dyn (85.7 KB)
sbim_17_crossMember_00.dyn (63.5 KB)
sbim_19_parapet.dyn (56.9 KB)
