I have a problem of different marks appearing for similar bars and it is not grouping some same rebars when i create schedule in sofistik.
As shown in the screenshot position number 17 and 19 are exactly similar bars of same dimensions. But have different marks.
i tried with deleting and copying the other bars. But nothing helped. Anyone knows a solution for this?
Thanks in advance.
Hi Anagha,
please check if the following parameters are also identical for the rebars that should be the same mark:
- SOFiSTiK_Assignment
- Bar Type
- SOFiSTiK_ShapeCode
- Hooks (if you have hooks, the Workshop Instructions should also be the same)
- Segment Lengths
- SOFiSTiK_BarLength
- (SOFiSTiK_Layer, SOFiSTiK_Member and SOFiSTiK_Revision, if these parameters are considered for equality check in the settings)
