Is it possible to run SSD from command line (Windows command prompt window) for specific project? I mean open SSD window, load pointed task, perform project calculation and close SSD window. Syntax
“C:\Program Files\SOFiSTiK\2022\SOFiSTiK 2022\ssd.exe” DIR+project.sofistik" starts SSD module and open project. Are there any switches corresponding “calculate all” / “save project” and “exit” commands?
SSD is only a GUI holding the other programs together.
The actual program doing the calculation is wps.exe and it has a batch counterpart sps.exe
You run a calculation with the following syntax (assuming the batch file is in the project folder): “C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\sps.exe” myproject.dat
Don’t know if it works with SSD-files, I mainly work with teddy (dat-files)
Thank you! You are right (unfortunately), it doesn’t work work with SSD. But it is good to know there are some “automatisation” possibilities. I need to get familiar with teddy coding.
there is a hidden feature from version FEA 2025 which is not yet documented.
You can run a SSD project and specific tasks via the executable ssd_calculate.exe (which you can find in the installation folder of SOFiSTiK FEA)
This is how you can run e.g. the project file “stu_tankstellendach.sofistik”.
