Rotate global coordinate system
I’m working on importing geometry from a Revit model using AMG and need to adjust the orientation of the global coordinate system, which has been inherited from the Revit model. Is there a way to modify or realign the global coordinate system after the import? Any guidance or best practices would be appreciated!
Hello fism,
After creating an analytical model with AMG, you can subsequently adjust the orientation of the elements with the “Modify” command, which is available for versions 2024 and 2025.
For walls, you can also influence the coordinate system in the AMG settings.
Cheers Nils
