Why do you want to change the coordinate system?
I don’t see any advantages.
In order to acchieve the desired flip, you have to invert the coordinates of the structure. As you see in the TEDDY script, the coordinates of the SARs don’t change. So the structure is just upside down.
So draw your system upside down, or use some filters in grasshopper to transform the coordinates of the BRPs.
If you find another method please let me know.
Thanks a lot for the answer. There is no advantage ist only how it is used to be done in my company and some of Dat files have to be updated with different z direction.
I think the limitation lies in Rhino because it is impossible to change the global coordinate system direction as in AutoCAD. In any case, I will change the Dat files and keep the z-axis facing upwards.
thanks for the suggestion, the thing lies in the positive or negative values of z coordinates. If z coordinates are positive using NEGZ will just flip the building as in picture above
