Hey,
how can i get the structure from Revit to SOFIPLUS? If I open SOFIPLUS in SSD while seeing the structure from Revit in SSD, I do not see anything in SOFIPLUS. Thank you!
first you need to open REVIT and export the model to SSD. Then in SSD you need to insert a SOFiPLUS(-X) graphical task. Open it by double clicking on it. Then in SOFiPLUS(-X) you need to import the model from SSD.
Command import is started via an icon on the ‘Tools’ tab called ‘Import’.
