Dear Support,
I installed Revit Version 2020, but I want to change the language to French.
In Revit - File - Options I couldn’t find the properties. Where can I change the language?
Thank and regards
Dear Support,
Thank and regards
If you want to change the language of the Revit program itself, please follow the following instructions:
If you want to change the language of the SOFiSTiK application in Revit, go in the Settings menu or in the Select Language dialog.
Since V2020, it is possible to set the language setting to “Revit”, which means that the software will automatically use the language of Revit or use the fallback english language.
I hope this helps.
Regards,
Xavier Martin | SOFiSTiK Consulting
