MAXIMA makes the superposition for this objective function as follows:
internal calculation of the stress values according to the function for the initial load cases using the internal forces and moments
then superposition using the defined combination rule with the stress values
saving and possible printout of the results as internal forces and moments which lead to the most unfavourable case for the objective function
SOFiSTiK saves the internal forces and moments in the CDB.
Important: you have to define an own result load case number at record SUPP … LC for the results of the objective function.
Then the results – internal forces and moments – should be available in GRAPHIC (WinGRAF).
With kind regards
Sabine Fahrendholz
Senior Product Manager
