Result viewer
Greetings Sofistik community.
I am a student, learning Sofistik as I have decided to use this software for my master thesis.
I started with simple beam as shown in the picture
There are two load cases.
  1. Self load
  2. Additional load of 7.8kN/m’
All calculations are done and without any errors.
When I try to use Diagram assist in the Result Viewer window for some reason it cannot generate graphic diagram (for example My) as this assistant cannot see my axis.
Here is the issue:
Please find that there is an actual Axis in the lower part of the picture.
Any idea?
To be honest I find Sofistik way of displaying results a bit complicated so any kind of advice is much appreciated!
P.S. Since I am a new forum user I can only attach one picture so I “glued” 4 pics in one picture.
Hi, to get startet with our software I recommend to use our online video tutorial.
A complex bridge video training (18h ind different chapters) you will find here:
A quick intro in our workflow you will find on YOUTUBE
https://www.youtube.com/playlist?list=PLkNZCJG1CDyNpD3T_PGbuETEMNS4kxVTx
All other videos you will find here
https://www.youtube.com/@SOFiSTiKAG
Hope that helps
Hi Martin,
Thank you for your reply.
Yes, I am following video tutorial from 2020, but I didn’t know there is a new set of videos for 2025 version of the program.
At the end I’ve managed to get the results using wingraf.
But still didn’t quite understood what have I missed in the Diagram assist in the Result Viewer.
I’ll check latest (2025 version) videos to stay up to date with the software features.
Have a great day!
