I’m running into a problem or bug. I try to export a grapic from the Sofistik Report Browser using the build in graphic-export. If I select .ps as the output-format I get the following error:
SOFiSTiK 2020-6.0.1292 GKX * Metafile Augabe
dach-wingraf.plb IS VERSION 120 WITH 1 PICTURES
INVALID TYPE SPECIFIED FOR GKS_V 0
*** ERROR 26 IN PROCEDURE GOPWK ***
Specified workstation cannot be opened
++++ Geraet 251 konnte nicht geoeffnet werden
RECHENZEIT 0, TOTAL 0
SOFiSTiK AG - Educational-Version -
GKX - Metafile Viewer V 2020-6.0 15.12.20 Seite: 1
+++++ 1 FEHLER UND 0 WARNUNGEN +++++
+++++ DATEN FEHLERHAFT, PROGRAMM ABGEBROCHEN +++++
Anyone had a similar Problem or knows how to get the .ps-Export working?
Other formats do work, but i want the picture in Postscript.
Thanks in advance
Dg
