I’m doing a seismic survey using DYNA and I need to check the relative displacement between my levels to validate my study. So I’m wondering how do I get this information ? In EC 8, this corresponds to section 4.4.3.2. with the following equation: dr x v < 0.005 h
With which program are you working at the moment?
The screenshot shows the TEDDY command “EXTR”.
The shown screenshot can be found within the DYNA manual:
TEDDY / SSD > Help > Manuals > All Manuals > dyna > chapter 3.16 “EXTR - Evaluation of Max. Internal Forces and Moments”
The command can be entered directly in a +prog DYNA calculation within the TEDDY.
I don’t see your screenshot, but I’m using Sofistik 2020-5.1 with Sofiplus-X as graphical processor. For example if I want Sofistik to calculate storey shear force, displacement and drift I would add EXTR MAX S_PT, EXTR MAX S_UT and EXTR MAX S_DT as separate lines in TEDDY under DYNA module before END statement? Example shown in screenshot:
