Record for compressive strut angle in shear design in the CDB Database
When i do a shear design for reinforced concrete, i get the required shear reinforcement amount. For this Sofistik iterates through different compression strut angles (theta). In the Report Browser i can see for each structural element which theta was used in design, however i can’t find them neither in Result Viewer nor in Graphic.
Since the theta is shown in report browser, i suspect it must be recorded in the CDB database. I couldn’t find a record key for the theta in the documentation. Is it somehow possible to extract theta from the database? If yes what is the record for it?
Thanks in advance,
Özgün
No this data is calculated and printed, but not saved inside the database.
Sorry no further acces for you.
