The command “Read Section CDB” returns only variables of a cross section.
In order to understand the command, you need to know, that SOFiSTiK uses different sets of variables with different scopes:
1.STO# - global variable: is saved within the database and can be used in different programs
2. LET# - local variable: only valuable within the current program
3. TVAR - local variable: only usable within the current cross section
Further information can be found within the AQUA manual.
SSD / TEDDY > Help > User Manuals > All Manuals… > aqua > 3.51 TVAR - Template Variables
The result for the command “Read Section CDB” is, that you have only access on the TVAR variables.
(Read Section of the TEDDY example > File > Examples > aqua > english > aqua33_bridge.dat)
