Hi!
I’m new to reading values out of the CDB using python, so I have what might be a simple question.
In the following code, I’m trying to read out the quad numbers, their respective nodes, and their group numbers. There doesn’t seem to be a record under CQUAD for group number, so my plan was to simply determine the group numbers by dividing the quad element numbers by the group divisor. To do this I also need to get the group divisor from the database, which I found under CSYST. The problem I’m having is that my code is returning two group divisors, so I’m curious what I’m doing wrong. I’m pretty sure it’s just outputting a duplicate of the group divisor, so I must have an indexing problem.
Any help on this would be greatly appreciated.
Thanks,
Grant
# import all types from sofistik_daten.py, original file can be found by following
# --> examples/python/sofistik_daten.py
sofistikFolderPath = r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\"
CDBFilePath = r"C:\Users\PC01\Desktop\Local_Copy\V1_Balcony.cdb"
import sys
sys.path.append(sofistikFolderPath + r"interfaces\examples\python")
from sofistik_daten import *
import os # for the environment variable necessary
import platform # checks the python platform
import string
from ctypes import * # read the functions from the cdb
# This example has been tested with Python 3.7 (64-bit)
print("The path variable=", os.environ["Path"])
# Check the python platform (32bit or 64bit)
print("Python architecture=", platform.architecture())
sofPlatform = str(platform.architecture())
# Get the DLL (32bit or 64bit DLL)
if sofPlatform.find("32Bit") < 0:
# Set environment variable for the DLL files
print("Hint: 64bit DLLs are used")
# Set DLL dir path - new in PY 3.8 for ctypes
# See: https://docs.python.org/3/whatsnew/3.8.html#ctypes
os.add_dll_directory(sofistikFolderPath + r"interfaces\64bit")
os.add_dll_directory(sofistikFolderPath[:-1])
# Get the DLL functions
myDLL = cdll.LoadLibrary("sof_cdb_w-2024.dll")
py_sof_cdb_get = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_get
py_sof_cdb_get.restype = c_int
py_sof_cdb_kenq = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_kenq_ex
else:
# Set environment variable for the dll files
print("Hint: 32bit DLLs are used")
os.add_dll_directory(sofistikFolderPath + r"interfaces\32bit")
myDLL = cdll.LoadLibrary("cdb_w31.dll")
py_sof_cdb_get = cdll.LoadLibrary("cdb_w31.dll").sof_cdb_get
py_sof_cdb_kenq = cdll.LoadLibrary("cdb_w31.dll").sof_cdb_kenq_ex
# Connect to CDB
Index = c_int()
cdbIndex = 99
# Set the CDB Path
# e.g. fileName = "S:\\test\\read_nodes.cdb"
# fileName = r"S:\test\read_nodes.cdb"
fileName = CDBFilePath
# important: Unicode call!
Index.value = myDLL.sof_cdb_init(fileName.encode("utf-8"), cdbIndex)
if Index.value == 0:
print("A database with the given file name does not exist and was created.")
cdbStat = c_int() # get the CDB status
cdbStat.value = myDLL.sof_cdb_status(Index.value)
# Print the Status of the CDB
print("CDB Status:", cdbStat.value)
grpDiv = []
qNr = []
qN1 = []
qN2 = []
qN3 = []
qN4 = []
pos = c_int(0)
datalen = c_int(0)
# Get system group divisor
# a = c_int()
ie = c_int(0)
datalen.value = sizeof(CSYST)
RecLen = c_int(sizeof(csyst))
do while ie == 0, see cdbase.chm, Returnvalue.
= 0 -> No error
= 1 -> Item is longer than Data
= 2 -> End of file reached
= 3 -> Key does not exist
while ie.value < 2:
ie.value = py_sof_cdb_get(Index, 10, 0, byref(csyst), byref(RecLen), 1)
print(csyst.m_igdiv)
grpDiv.append(csyst.m_igdiv)
# Always read the length of record before sof_cdb_get is called
# Get Quad element numbers and node numbers
# a = c_int()
ie = c_int(0)
datalen.value = sizeof(CQUAD)
RecLen = c_int(sizeof(cquad))
while ie.value < 2:
ie.value = py_sof_cdb_get(Index, 200, 0, byref(cquad), byref(RecLen), 1)
qNr.append(cquad.m_nr)
qN1.append(cquad.m_node[0])
qN2.append(cquad.m_node[1])
qN3.append(cquad.m_node[2])
qN4.append(cquad.m_node[3])
# Close the CDB, 0 - will close all the files
myDLL.sof_cdb_close(0)
# Print again the status of the CDB, if status = 0 -> CDB Closed successfully
if cdbStat.value == 0:
print("CDB closed successfully, status = 0")
