Hello, I’m a bit late, but I have a similar question. I found the example in the installation folder and got it working, however I would like to read the design results [107] instead of the nodes [20]. I don’t know how to adapt the example, maybe someone has an Excel file with the function?
In the folder:
C:\Program Files\SOFiSTiK\2023\SOFiSTiK 2023\interfaces\examples\vba
Check out the following files:
cdb2excel_2018_1.xlsm
sofistik_daten.bas
The first is complete template for importing data to excel and the second has the necessary structs in vba format.
You can find sofistiks code for 107 in the module_beams module in vba:
Thanks for your help, unfortunately I’m quite a beginner when it comes to vba.
In the read node example (C:\Program Files (x86)\2022\SOFiSTiK 2022\interfaces\examples\vba\read_nodes\read_nodes_64-bit.xlsm) I can paste my file path and get the node information.
I need something similar for the design results. There is no such thing in the module_beams code.
I took the working nodes module (read_nodes_64-bit.xlsm):
Option Explicit
'| Company: SOFiSTiK AG |
'| Version: SOFiSTIK 2022 |
'Read the nodes from CDB
Public Sub readNodes()
Dim Filename As String
Dim Index, datalen As Long
Dim row, pos As Long
Dim arr_20_0() As Variant
ReDim arr_20_0(6, 0)
Dim Destination1 As Range
'Lets clear the sheet first
tab1.Cells.Clear
'The path of the file
Filename = tab1.TextBox1.Text
'To connect to the CDB we will use
Index = sof_cdb_init(Filename, 99)
'Get the data from CDB
Dim data As CNODE
datalen = Len(data)
Do While sof_cdb_get(Index, 20, 0, data, datalen, pos) = 0
row = row + 1
pos = pos + 1
'Redim the array for the output
ReDim Preserve arr_20_0(6, row)
'Copy the values to array
arr_20_0(0, row) = data.m_NR
arr_20_0(1, row) = data.m_INR
arr_20_0(2, row) = data.m_KFIX
arr_20_0(3, row) = data.m_NCOD
arr_20_0(4, row) = data.m_XYZ(1)
arr_20_0(5, row) = data.m_XYZ(2)
arr_20_0(6, row) = data.m_XYZ(3)
'Get the length of the data. This is very important!!!
datalen = Len(data)
Loop
'Set the names of header row and columns
arr_20_0(0, 0) = "NR"
arr_20_0(1, 0) = "INR"
arr_20_0(2, 0) = "KFIX"
arr_20_0(3, 0) = "NCOD"
arr_20_0(4, 0) = "X"
arr_20_0(5, 0) = "Y"
arr_20_0(6, 0) = "Z"
'Output the values to range
Set Destination1 = tab1.Range("A4")
Destination1.Resize(UBound(arr_20_0, 2) + 1, UBound(arr_20_0, 1) + 1).Value = Application.Transpose(arr_20_0)
'Center the output -> this is just for better looking
tab1.Cells.HorizontalAlignment = xlCenter
'Close the CDB
Call sof_cdb_close(0)
End Sub
copied it and changed some values, but the loop is always skipped:
Option Explicit
'Read the designresults from CDB
Public Sub readDesignresults()
Dim arr_107_0() As Variant
ReDim arr_107_0(40, 0)
tab1.Cells.Clear
Dim data As CBEAM_DE0
datalen = Len(data)
Do While sof_cdb_get(Index, 107, 0, data, datalen, pos) = 0
row = row + 1
pos = pos + 1
ReDim Preserve arr_107_0(40, row)
arr_107_0(0, row) = data.m_NR
arr_107_0(1, row) = data.m_X
arr_107_0(2, row) = data.m_NI
arr_107_0(3, row) = data.m_MYI
arr_107_0(4, row) = data.m_MZI
arr_107_0(5, row) = data.m_SCF
arr_107_0(6, row) = data.m_E0
arr_107_0(7, row) = data.m_EY
arr_107_0(8, row) = data.m_EZ
arr_107_0(9, row) = data.m_E1
arr_107_0(10, row) = data.m_E2
arr_107_0(11, row) = data.m_HL
arr_107_0(12, row) = data.m_HVM
arr_107_0(13, row) = data.m_HX
arr_107_0(14, row) = data.m_EDCMIN
arr_107_0(15, row) = data.m_EDCMAX
arr_107_0(16, row) = data.m_FCHK
arr_107_0(17, row) = data.m_TCF
arr_107_0(18, row) = data.m_SCN
arr_107_0(19, row) = data.m_SCVY
arr_107_0(20, row) = data.m_SCVZ
arr_107_0(21, row) = data.m_SCMT
arr_107_0(22, row) = data.m_SCMY
arr_107_0(23, row) = data.m_SCMZ
arr_107_0(24, row) = data.m_SCMB
arr_107_0(25, row) = data.m_SCT2
arr_107_0(26, row) = data.m_SCCOMB
arr_107_0(27, row) = data.m_SCBN
arr_107_0(28, row) = data.m_CSIGC
arr_107_0(29, row) = data.m_CSIGT
arr_107_0(30, row) = data.m_CTAU
arr_107_0(31, row) = data.m_CSGV
arr_107_0(32, row) = data.m_CSGR
arr_107_0(33, row) = data.m_CAS
arr_107_0(34, row) = data.m_CASL
arr_107_0(35, row) = data.m_CCW
arr_107_0(36, row) = data.m_CSGD
arr_107_0(37, row) = data.m_CTAU0
arr_107_0(38, row) = data.m_C2T
arr_107_0(39, row) = data.m_CLASS
datalen = Len(data)
Loop
arr_107_0(0, 0) = "nr"
arr_107_0(1, 0) = "X"
arr_107_0(2, 0) = "NI"
arr_107_0(3, 0) = "MYI"
arr_107_0(4, 0) = "MZI"
arr_107_0(5, 0) = "SCF"
arr_107_0(6, 0) = "E0"
arr_107_0(7, 0) = "EY"
arr_107_0(8, 0) = "EZ"
arr_107_0(9, 0) = "E1"
arr_107_0(10, 0) = "E2"
arr_107_0(11, 0) = "HL"
arr_107_0(12, 0) = "HVM"
arr_107_0(13, 0) = "HX"
arr_107_0(14, 0) = "EDCMIN"
arr_107_0(15, 0) = "EDCMAX"
arr_107_0(16, 0) = "FCHK"
arr_107_0(17, 0) = "TCF"
arr_107_0(18, 0) = "SCN"
arr_107_0(19, 0) = "SCVY"
arr_107_0(20, 0) = "SCVZ"
arr_107_0(21, 0) = "SCMT"
arr_107_0(22, 0) = "SCMY"
arr_107_0(23, 0) = "SCMZ"
arr_107_0(24, 0) = "SCMB"
arr_107_0(25, 0) = "SCT2"
arr_107_0(26, 0) = "SCCOMB"
arr_107_0(27, 0) = "SCBN"
arr_107_0(28, 0) = "CSIGC"
arr_107_0(29, 0) = "CSIGT"
arr_107_0(30, 0) = "CTAU"
arr_107_0(31, 0) = "CSGV"
arr_107_0(32, 0) = "CSGR"
arr_107_0(33, 0) = "CAS"
arr_107_0(34, 0) = "CASL"
arr_107_0(35, 0) = "CCW"
arr_107_0(36, 0) = "CSGD"
arr_107_0(37, 0) = "CTAU0"
arr_107_0(38, 0) = "C2T"
arr_107_0(39, 0) = "CLASS"
Destination1.Resize(UBound(arr_107_0, 2) + 1, UBound(arr_107_0, 1) + 1).Value = Application.Transpose(arr_107_0)
'Close the CDB
End Sub
If you want your file to work:
You need to pick a loadcase
means: loop for 107/0, you probably don’t have that key but 107/LC (replace the 0) -
If you want to use the prepared file
cdb2excel_2018_1.xlsmjust go to the sofistik ribbon:
The necessary tools are there.
Thank you so far. It works now and gives me the values, but somehow there are different values in the database than in the report browser. I compared the moment and they are different values, only 0 and 135 are the same.
What can be the reason for this?
Just a guess by going with the screenshots:
- Result browser: Actual forces according to the loadcase
- cdb: Maximum design forces (i.e. capacity) :
107/LC: BEAM_DES | Ultimate/Plastic Design results`
