Is it possible to some how access (set as currect project) CDB from sub-directory.
Like:
#define project=”"subfolder/cdbname” - this is not working unfortunatly
Is there some other way to define path to subfolder so $(project) will work?
What are you trying to do?
Maybe replace the / with \ ?
This works for example:
#DEFINE PROJECT="dummy\cdbname"
+PROG TEMPLATE
KOPF
TXE $(PROJECT)
ENDE
and shows “dummy\cdbname” in the report file.
Yea I figured it out (tried both / \ ofcourse)
It works #define project=“subfolder\projectname”
but you cant have any spaces in project name or folder name which I previously had
