I started project in SSD and created bridge model in SofiPlus. Everything was ok, but when I open same project later, there is no sidebar and I cannot edit anything in Sofiplus. If I try to select any object I get FATAL ERROR. When I tried opening some other projects I did get same error…
Hello Ahmed
Have you opened the project with SOFiPLUS(-X) or with AutoCAD?
It could be that your standard app for .dwg files is AutoCAD. So if you open a SOFiPLUS(-X) file via double-click, the file is opened with AutoCAD.
In SOFiPLUS(-X) you can try to use the command “sof_g_gexplorer” to enable the sidebar.
If this command does not reveal the sidebar, the sidebar might be hidden on a secondary screen.
I opened project with SOFiPLUS from SSD. I tried with command “sof_g_gexplorer”and sidebar appears, however, i cannot do anything with it because commands do not respond (No active database). In sidebar, System it says “This drawing does not contain SOFiSTIK project”.
Thanks in advance on your help…
Ahmed
please help me
I came across this message
“this drawing dose not contain a sofistik project”
Did you follow the steps outlined?
Can you please describe your procedure? I can’t help you without more information…
Have you installed the latest program updates?
Apart from that, please check the work directory and the name of the project.
The workdirectory should not contain any special characters (like ë, Ð).
Mr. Holler
I saved the file without special letters and shapes. But still my problem was not solved
