When defining Placements along an axis using the Axis Placement by Parameter component, a local working plane (placement plane) is created. The working planes are aligned perpendicular to the axis and additional rotations can be specified. However, is it possible to specify a curvature? For example, is it possible to have abutment walls with a curvature following an additional alignment of an underlying road?
Hello Johan
I am not completely sure what you want to model. Could you maybe draw a quick sketch?
All possible inputs of the command "Axis Placement by Parameter are described in the grasshopper manual on our website.
https://www.sofistik.de/documentation/2022/en/rhino_interface/grasshopper/components/AxisPlacementByParameter.html
Hi Frederik,
I am trying to model a concrete closed portal frame bridge/underpass. The bridge has a skew and the frame legs are curved, having a radius, following the alignment of the underlying road. I am having trouble finding a good approach taking into account both the radius and the skew.
Johan
