I have 2 beams that only cross sections are different, one is solid section, the other one is hollow section. Both beams have steel parts (4 angles), concrete and tendon.
Solid section
Hollow section
The construction stages are as follows
| CS | NO | TYPE | T | TITL | |
| 10 | G_1 | 0 | ‘Steel Angles’ | ||
| 20 | G_1 | 0 | ‘Concrete’ | ||
| 30 | C | 10 | ‘C + S’ | ||
| 40 | P | 0 | ‘Post-tensioning’ |
For solid section, the analysis is successful, but for hollow section, the analysis result will depend on the size of tendon duct.
The area of steel (4 angles) is about 24764mm2 according to Aqua. The equvalent diameter of the area is 0.25 x pi x dia^2 = 24764, dia = 177.6 mm
If tendon duct <= 177.6 mm, the analysis for hollow section is successful. If tendon duct > 177.6 mm (DO = 178), the analysis for hollow section is unsuccessful, it aborted at AQB CS 30 (Creep and Shrinkage),
| +PROG | Tendon | |||||||||||
| HEAD | ||||||||||||
| SYSP | NOPS | MAT | ZV | AZ | LITZ | MINR | BETA | MUE | ECC | SP | DO | |
| 1 | 2 | 1822.8 | 1400 | 10 | 7 | 0.343774677 | 0.25 | 0 | 6 | 178 |
the error message are:
Start: Program AQB : creep step CS 30 C + S
+++++ error no. 70011 in program INIT_LOCATIO
Negative sectional area in cross section 2 CS 0 = 10
Please check construction stage numbers and if the ducts for tendons are defined to large
I have several questions:
- I gusss the “Negative sectional area in cross section 2 CS 0 = 10” means: at CS 10,
24764mm^2 (area of 4 angles) - 0.25 x pi x (178mm)^2 (area of duct) = -120 mm^2
Why Sofistik consider tendon at CS 10, when only steel is activated? The tenon should be consider at CS 40. - Solid section has the same tendon as that of hollow section, but the analysis is always successful even if I use duct size = 500 mm for solid section.
The dat files are as follow. Plz put all dats in one folder.
Hollow - 177.dat is for hollow section with duct size = 177mm < 177.6mm, the analsis is successful;
Hollow - 178.dat is for hollow section with duct size = 178mm > 177.6mm, the analsis is unsuccessful;
Solid - 500.dat for solid section with duct size = 500mm >> 177.6mm, the analsis is successful
Aqua.dat (1.9 KB)
SofimshC - Hollow.dat (721 Bytes)
SofimshC - Solid.dat (721 Bytes)
Tendon - 177.dat (1.0 KB)
Tendon - 178.dat (1.0 KB)
Tendon - 500.dat (1.0 KB)
SofiLoad.dat (175 Bytes)
CSM.dat (299 Bytes)
Hollow - 177.dat (140 Bytes)
Hollow - 178.dat (140 Bytes)
Solid - 500.dat (139 Bytes)
