PC configuration
Hello everyone,
I am new to SOFiSTiK.
I want to build a PC which will fully satisfy my SOFiSTiK needs.
Are there any system requirements/recommendations for SOFiSTiK in terms of graphic card, RAM or processor?
Thank you
Hello Nikola,
We can only give you a general hardware recommendation.
  • multicore processor (ASE ->CORE HISOLV)
  • 16 GB RAM
  • SSD
  • The graphics hardware is not necessary for the calculation, but has an impact on the visualization of the system and when working with SOFiPLUS(-X) (or Revit / Rhino). For this reason, it is best to choose an Autodesk (AutoCAD) recommended graphics card. System Requirements | Autodesk Knowledge Network
It seems like you get the most bang for your buck if you buy the latest generation.
Comparing for instance ASE run times for different CPUs the latest “runner up” CPU is often better than last years top of the line model.
Seems like updated processor instructions have a greater impact than specs.
I suspect the same goes for ram/ssd.
