Does anybody know if it is possible to open Sofiplus (or maybe only the cross section editor) without using SSD ? Like we can open the animator or wingraf.
Thank you!
Andrei
Thank you!
Andrei
If you want to work on an existing file → Open the dwg with the same name as the cdb
If you want to create something from scratch → Save the dwg with the intended project name
