Obtain Read Section Library
I’m running into an issue which I’m not able to find the component called “Read Section Library”
Thanks for your assistance.
Hi Merv,
The Read Section Library was removed in Version 2023. It was replaced by Read Section Json which has the functionality covered.
Old link:
https://docs.sofistik.com/2022/en/rhino_interface/grasshopper/components/ReadSectionLibraryJSON.html
New Link:
https://docs.sofistik.com/2024/en/rhino_interface/grasshopper/components/ReadSectionJSON.html
Old and already created projects can handle Library and still use it in the newer versions, it can not be added anymore though.
Hi @A.Freund ,
I have a similar problem. But when i define sectionattirbutes like before and use the “ReadSec JSON” component what is the input I need to put in the “Path” ?
I just want to create a steel section in grasshopper using the sofistik plugin.
I would be happy over an answer.
