Hi, any ideas why the temporary supports don’t turn off? I’ve checked and the node over the support cause it. The node is added because it is only way to add working displacement force. The calculations went well but graph shows that the support are still active.
You can’t disable supports independently because they are properties of nodes.
For temporary supports I usually use spring elements in separate groups. They can be activated and deactivated using the group control.
Regards
gmay
Hi wojtiqq,
when you upload the system and describe where I can see what you describe probably I will able to help.
Regards,
Jost
Thank you, but I’ve solved the problem
