Normal force / moment interaction diagram
Hello.
I have a question. Does any of you know if Sofistic allows an automatic/semi-automatic display of normal force/moment interaction diagrams? I did some research but I couldn’t find any information about this.
Example. I modeled a column and I would like to display the normal force/moment interaction diagram while taking into consideration the properties (geometry and reinforcement) of said column.
Does Sofistik give this option? I usually use other programs to do it while taking the maximum reactions from Sofistik.
There is the command CAPA in module PROG AQB that is supposed to be able to create diagrams of sectional capacities.
