Hi all,
one of my colleague showed me a feature within Sofistik that I did no know existed.
Essentially, if I wanted to perform a structural analysis for tension only bedding for quad elements (i.e. structural areas) but without limitation to the compression stress, there is no need to define a specific material bedding.
It is sufficient to perform a non linear springs and bedding analysis for the normal bedding defined in the quad definition. Is this correct?
I did tested this feature myself and effectively it seams to work, however in all the guides/tutorial/videos I’ve seen it is always mentioned that a specific material bedding must be defined (with non linear analysis) to allow for compression only.
Essentially, by default, for a non-linear analysis ASE will cut-off the tensile stress automatically if a normal bedding is defined. Is this also applied to the transverse bedding?
I tried to find the explanation in the manuals about this but with no success, could someone provide some refence of this in the manual?
Thanks.
