Multiple Results in same Diagram in Result Viewer
Hi All,
is it possible to show multiple results in a Diagram in result viewer?
More specifically, after a dynamic analysis, I would like to plot displacement and rotation vs time of a specific node and for comparison purposes, I’d like there two curves to be in the same diagram.
I have the results in tabular form and I know I could do this in Excel. It would be advantageous to do it directly into Sofistik to avoid back and forth as I calibrate the model.
Thanks.
Yes this is possible.
Inside Result Viewer use the table you have created and click on the button “Diagramm”
Then goto the menu “Diagram” and click on “Graph” to define additional settings for every single graph.
That’s all.
There are some Table and Diagram Assistant options: goto menu “Result” and click " Add/hinzufügen"
Now you will be guided how to create some standard tables or diagrams.
grafik
Please note: All screenshots are done from a task “Interactive List and Graph” inside a 2025 version SSD project in German language!
Hi Martin,
thanks for the reply, however I’m aware that you can have results of multiple nodes in the diagram, what I’m trying to do is to have multiple results for the same node.
In other words, multiple selection for the Y axis.
Do you know of a way of doing this into Result Viewer?
Thanks.
