Is it possible to reduce the bending/shear stiffness of columns and wall elements without affecting their vertical stiffness in Sofistik/Teddy. If so how should I go about doing it?
I am wanting to reduce the by 50% to account for concrete cracking in my elastic analysis in accordance with Eurocode 8.
I am aware that I could simply reduce my E-Modul by 50% to achieve this but this would also reduce the vertical stiffness. Unfortunately we are also interested in the vertical response of the structure so reducing the vertical stiffness is not an option.
Another option is to use the command SVAL to modify the properties that I am interested in (e.g. Iy, Iz) however the manual says that this will remove the geometry from the section and that it can be used only for static analyses.
Is there an option that retains the geometry/can be used for dynamic time history analyses?
Thanks in advance for any help you can provide.
