Meshing with sofimshC and sofimshA
Hi Alexia,
the reason why you get an element size of 0,5 m instead of 1 m is that every edge is divided by an even number of elements. Every edge between two structural points is divided into two sections.
This is explained in the sofimshc-manual. The reason behind this is that first a triangular mesh is created and from that a quadrilateral mesh.
Best regards, Nora
