The VMIS material model cannot be used in ASE for nonlinear quad calculation.
As already mentioned, please use STEE or CONC material definitions instead of MATE. The nonlinear MATE material is fro example intended for use with PROG TALPA.
For reference, you may have a look at the TEDDY examples located in the “nonlinear-quad” folder in our examples. These examples demonstrate different approaches for defining nonlinear material behaviour in ASE and may help you set up your model accordingly.
