I’m setting up a secondary workstation at home for SOFiSTiK modeling and post-processing, and space on the desk is tight, so I’ve been considering a compact mini PC instead of a full tower. The one I keep coming back to is built around a Ryzen 4300U with integrated graphics, which seems fine for general desktop work but I’m unsure how it behaves once models get larger or when I want to look at results in 3D on a second screen.
My main concern is memory and thermals: these small form factor units often cap out at soldered RAM, and the fan may not cope with long solver runs even if the CPU is technically adequate. I’m also not clear whether the integrated GPU is a bottleneck for visualization only, or whether it affects anything else.
Has anyone here run SOFiSTiK on a mini PC like this? I’d appreciate hearing how it handled real projects and where it started to struggle.
I found this KAMRUI Pinova P2 Ryzen 4300U Mini PC Review while comparing options. It covers specs and thermals, but I’m still unsure whether soldered RAM and the fan would hold up during longer solver runs.
