I defined different load cases in load case manger, like(self weight, live load etc.) but i am asking how to combine all these loads together to make the software calculate them with each other and not as separated cases?
Please try to work yourself through our basic (bridge design) tutorials. These Youtube videos cover all the necessary workflows when working with our software.
SOFiSTiK Beginner Tutorial:
SOFiSTiK Bridge Design Training:
So you have watched all of the 26 videos? I only sent you the first videos of the playlist.
I am sure those videos explain the basics of the superositioning.
I have watched most of the videos in the playlist especially the first ones. I watched videos from number 1 till number 6 and also i watched video number 9 which is for traffic loader.
but anyway thank you and will try to watch this video again and solve the problem
Actually, Sofistik does not combine load cases with each oteher, but you have to calculate load cases and then make combinations of the results of load cases.
